There are two formulas that my book gives to calculate maximum current and average current through a diode of a full wave rectifier. I was wondering what are those represented as on a diode's data sheet. the formulas are:
i dmax = IL(1 + 3.14×√Vp/2×Vr)
i av = IL(1 + 2×3.14 ×√Vp/2×Vr)
Vr is the ripple voltage peak to peak
IL is the load current
Vp is the peak output voltage of the supply
The values that i get when i calculate i av don't match anything that are provided on the diode's datasheets and i know that this diode can be used. i also see similar current values when i simulate rectifier circuit in p spice and look on current going through the diode. There is one big current surge, which is similar in value to the calculated value of i max, and smaller spikes that are similar in value to those of calculated i av.
Another question that i have is about voltage regulators
if you have a voltage regulator circuit and the load across it's output does not change, the voltage regulator circuit draws the same current, regardless of the input voltage put across it's input, right?
how can you simulate a load that draws the same current regardless of the voltage applied across it's input in p spice?
i use p spice student version
