Question about output accuracy integrating circuit
firsttimedesigning
Full Member level 1
Full Member level 1
I am trying to design an op-amp that is going to be used in an integrating circuit for integrating ADC. The trouble that I am having is that the integrating circuit's output is not accurate enough. For example, when the output is suppose to be 0.5V, it is 0.483V instead. Even if I use an ideal op-amp, the output is still not accurate enough. It is 0.494V instead of 0.5V. I would like the actual output to be at least 200uV within the theoretical output. Any idea how to do it?
Re: Op-Amp
what is your DC gain, bandwidth and UGB? It sounds like related to DC gain.
Re: Op-Amp
Go study Ch2 and Ch6 of this book:
Op Amps for Everyone , by Ron Manchini.
You can find the books at:
