Jan 18, 2008 #1 R rivendu Junior Member level 3 Joined Dec 14, 2007 Messages 25 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,495 hallo, i would like to optimize a circuit towards each of the following corners: - low power dissipation - high speed - high resolution is monte carlo the best method to find the right dimensions for each transistor to match one of the corners? are there other strategies? thanks
Jan 20, 2008 #2 A Abbigeri Newbie level 5 Joined May 24, 2007 Messages 8 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location Tokyo Activity points 1,338 with monte carlo u can estimate only yield of the circuit.i think you should use sensitivity, optimizer and smoke analysis.
