Questio about 2 output (+, -) regulator IC
wichayen
Member level 2
Thailand
Does anyone knows the regulator IC like below?
Now, I try to find some regulator that can generate 2 output (pulse and minus). That IC has the pin that can control output pulse or minus. Does anyone knows information about this IC.
Input: 12 V
Output: +5 or -5V (voltage selectable is more useful)
Thank you!
are you sure the IC needs only +12V to generate both the +/- 5 outputs?
i've heard of only ic ACT8600,which is a dual regulator with outputs + and - ,but it also needs the input to be - .not like what you said.
Yes, Actually the input side is connected to car battery.
I think, actually I can generate 2 output of +5 and -5 V and select by mechanical switch. But I concern about lifetime of mechanical switch and some noise when switching mechanical switch. So I try to find that IC.
It may be very difficult to find off-the-shelf circuit like that ..
How about steping voltage down to 5V and using H-Bridge configuration switch the outputs .. It's like driving a motor and changing direction .. see this pdf:
http://www.discovercircuits.com/PDF-FILES/HBRIDGE2.pdf
Regards,
IanP
    wichayen
It had to be step-down DC-DC converter chip.
Since no spec. is given try looking in Linear Tech or Maxim website for such part.
I don't know if this will help but Analog produces something like this
ADP3330 High Accuracy Ultralow I(Q), 200 mA, SOT-23, anyCAP® Low Dropout Regulator
See if that's what you want. This one has only one output but check if there are any two output ones.
I remember there was also ADP1173 which I think did 12v to 5v...
