Nov 13, 2006 #1 V vsrpkumar Member level 4 Joined Mar 26, 2006 Messages 74 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,830 A system has 3 clocks inside and they are derived from main clock.In clock constraints, is it better to define them seperately or by derived clocks in primetime kumar
Nov 13, 2006 #2 F fzhang Newbie level 6 Joined Nov 5, 2006 Messages 13 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,283 Activity points 1,334 i suggest to derive the clocks from the main clock, in this way you constraint is more consistant with the design and easy to follow.
Nov 20, 2006 #3 Raptor Member level 2 Joined Jul 6, 2001 Messages 49 Helped 7 Reputation 14 Reaction score 5 Trophy points 1,288 Activity points 369 Its better to define it as generated clocks. Because once you switch to post-layout this will ensure right network delay is calculated.
