Quartus VHDL file order...
davorin
Advanced Member level 3
Switzerland
Is this normal that Quartus requires VHDL files to appear in bottom-to-top order whereas it doesn't care vor Verilog files order?
Or is this just normal behaviour of the "use work.blah.moreblah" thingie?
Hi Davolin
In Qu@rtus u only have to keep Topmost entity(or module) at the bottom while adding project files.Other files can be in any order.
Regards
Jas
Re: qu@rtus VHDL file order...
Wrong...it applies to every vhdl file containing sub-modules...
Hi Dear
I did it myself successfully in many projects.So u can take my wods.
Regards
Jas
agree wth jas_bakshi...
u just need to create a topmost project directory n project name in quartus(same as ur topmost vhdl entity)... n put all ur submodule inside the directory....u dont even need to rerun the submodule compilation... compiling the topmost file will do all the works,,,,
regards,
sp
