does not exist in macrofunction
Hi guys,
I having trouble compiling my VHDL code below on quartus:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity mux_8X8 is
port(A,B: in std_logic_vector(7 downto 0);
start, reset, clk: in std_logic;
y: buffer std_logic_vector(15 downto 0);
leds: out std_logic_vector(1 to 7);
done_flag: out std_logic);
end mux_8X8;
architecture behave of mux_8X8 is
signal aout,bout: std_logic_vector(3 downto 0);
signal sel,shift,count: std_logic_vector(1 downto 0);
signal state_out: std_logic_vector(2 downto 0);
signal clken,regclr:std_logic;
signal product: std_logic_vector(7 downto 0);
signal x,sum: std_logic_vector(15 downto 0);
component adder_16
port(x,y: in std_logic_vector(15 downto 0);
sum: out std_logic_vector(15 downto 0));
end component;
component mux2_to_1
port(A,B: in std_logic_vector(3 downto 0);
sel: in std_logic;
y: out std_logic_vector(3 downto 0));
end component;
component seg_7
port(bcd:in std_logic_vector(2 downto 0);
leds
ut std_logic_vector(1 to 7));
end component;
component shifter8_16
port(input:in std_logic_vector(7 downto 0);
cnt:in std_logic_vector(1 downto 0);
result:buffer std_logic_vector(15 downto 0));
end component;
component register_16
port(clk, clr,clken: in std_logic;
D: in std_logic_vector(15 downto 0);
Q: out std_logic_vector(15 downto 0));
end component;
component counter_2
port(clk,clr: in std_logic;
Q: out std_logic_vector(1 downto 0));
end component;
component mult4x4
port
(dataa : IN STD_LOGIC_VECTOR (3 DOWNTO 0);
datab : IN STD_LOGIC_VECTOR (3 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR (7 DOWNTO 0));
end component;
component state_machine
port( clk, rst, start: in std_logic;
count: in std_logic_vector(1 downto 0);
in_sel,shift: out std_logic_vector(1 downto 0);
state_out: out std_logic_vector(2 downto 0);
done,clken,regclr: out std_logic);
end component;
begin
Adder: adder_16 port map(x,y,sum);
Mux4A: mux2_to_1 port map(A(3 downto 0), A(7 downto 4), sel(1),aout);
Mux4B: mux2_to_1 port map(B(3 downto 0), B(7 downto 4), sel(0),bout);
Seven: seg_7 port map(state_out,leds);
Shifter1: shifter8_16 port map(product,shift,x);
Reg : register_16 port map(clk,regclr,clken,sum,y);
Counter: counter_2 port map(clk,not(start),count);
Mult4x4_1: mult4x4 port map(aout,bout,product);
Control: state_machine port map(clk, reset,start,count,sel,shift, state_out,done_flag,clken,regclr);
end behave;
error msg
Error: Port "Q" does not exist in macrofunction "Counter"
Error: Port "D" does not exist in macrofunction "Reg"
Error: Port "Q" does not exist in macrofunction "Reg"
Error: Port "result" does not exist in macrofunction "Shifter1"
Error: Port "bcd" does not exist in macrofunction "Seven"
Error: Port "leds" does not exist in macrofunction "Seven"
