JohnG300c
I'm using a Cyclone II to implement a small state machine. Quartus II 7.1 SP1 is giving me a headache since it refuses to generate a correct state machine which has two possible paths from a state (if 'A' then next state = X, if 'B' then next state = Y). The resulting state machine (accordingly to the state machine viewer and the actual functionality) only has next state transition to state X. Below is the code snippets and attached is the Verilog file.
The following next-state transition criteria (see linkstate.v in attached zip file):
WAIT_CONNECT_STATE:
begin
if(DIR == 1'b1 && DATA == LSJ_DATA)
nextstate = SEND_LS_CMD_STATE;
if(DIR == 1'b1 && DATA == FSJ_DATA)
nextstate = WAIT_FS_SE0_STATE;
end
Will result in the following next state table (See 'State Machine Viewer States.txt' in the attached zip file):
WAIT_CONNECT_STATE SEND_LS_CMD_STATE (N_RESET).(DIR).(Equal1:OUT) + (N_RESET).(DIR).(Equal0:OUT)
WAIT_CONNECT_STATE WAIT_CONNECT_STATE (N_RESET).(!DIR) + (N_RESET).(!Equal1:OUT).(!Equal0:OUT)
WAIT_CONNECT_STATE RESET_STATE (!N_RESET)
NOTE that the resulting state machine does not ever go to the WAIT_FS_SE0_STATE state. It doesn't matter how i change the transition critera, one or the other transntion will survive synthesis, never both.
Can anyone shed some light on this issue???
I have also attached an .xls file which contains the next state table per the design.
Thanks,
/John.
WAIT_CONNECT_STATE:
begin
end
Thanks,
/John.
