PWM using controller
Can you use ATTiny2313 or 4313 ? ATTinly25/10 doesn't have ICPx pin for input capture.
If you still want to use ATTiny25 then Timer0 has to be used to find the duty of the input PWM using INT0pin and then Timer1 has to be used for getting PWM output.
As of now I was able to generate 100 Hz Variable PWM duty PWM in ATTiny25 using Timer1 and CodeVisionAVR. ATTiny25 doesn't have ICPx pin and hence input capture feature is not available. I will use T0/INT0 with Timer0 to find the duty of the input PWM. This will be assigned to output PWM duty.
See attached simulation video.
This is the code.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
This program was created by the CodeWizardAVR V3.28
Automatic Program Generator
© Copyright 1998-2016 Pavel Haiduc, HP InfoTech s.r.l.
[url]http://www.hpinfotech.com[/url]
Project :
Version :
Date    : 8/23/2017
Author  :
Company :
Comments:
Chip type               : ATtiny25
AVR Core Clock frequency: 8.000000 MHz
Memory model            : Tiny
External RAM size       : 0
Data Stack size         : 32
#include <io.h>
#include <delay.h>
// Declare your global variables here
int i = 0;
void main(void)
// Declare your local variables here
// Crystal Oscillator division factor: 1
#pragma optsize-
CLKPR=(1<<CLKPCE);
CLKPR=(0<<CLKPCE) | (0<<CLKPS3) | (0<<CLKPS2) | (0<<CLKPS1) | (0<<CLKPS0);
#ifdef _OPTIMIZE_SIZE_
#pragma optsize+
#endif
// Input/Output Ports initialization
// Port B initialization
// Function: Bit5=Out Bit4=Out Bit3=Out Bit2=In Bit1=Out Bit0=Out
DDRB=(1<<DDB5) | (1<<DDB4) | (1<<DDB3) | (0<<DDB2) | (1<<DDB1) | (1<<DDB0);
// State: Bit5=0 Bit4=0 Bit3=0 Bit2=P Bit1=0 Bit0=0
PORTB=(0<<PORTB5) | (0<<PORTB4) | (0<<PORTB3) | (1<<PORTB2) | (0<<PORTB1) | (0<<PORTB0);
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Fast PWM top=0xFF
// OC0A output: Non-Inverted PWM
// OC0B output: Disconnected
TCCR0A=(1<<COM0A1) | (0<<COM0A0) | (0<<COM0B1) | (0<<COM0B0) | (1<<WGM01) | (1<<WGM00);
TCCR0B=(0<<WGM02) | (0<<CS02) | (0<<CS01) | (0<<CS00);
TCNT0=0x00;
OCR0A=0x00;
OCR0B=0x00;
// Timer/Counter 1 initialization
// Clock value: 15.625 kHz
// Mode: PWMA top=OCR1C
// OC1A output: OC1A=PWM, /OC1A=/PWM
// OC1B output: Disconnected
// Timer Period: 9.984 ms
// Output Pulse(s):
// OC1A Period: 9.984 ms Width: 5.0242 ms
// Timer1 Overflow Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
PLLCSR=(0<<PCKE) | (0<<PLLE) | (0<<PLOCK);
TCCR1=(0<<CTC1) | (1<<PWM1A) | (0<<COM1A1) | (1<<COM1A0) | (1<<CS13) | (0<<CS12) | (1<<CS11) | (0<<CS10);
GTCCR=(0<<TSM) | (0<<PWM1B) | (0<<COM1B1) | (0<<COM1B0) | (0<<PSR1) | (0<<PSR0);
TCNT1=0x00;
OCR1A=0x4E;
OCR1B=0x00;
OCR1C=0x9B;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=(0<<OCIE1A) | (0<<OCIE1B) | (0<<OCIE0A) | (0<<OCIE0B) | (0<<TOIE1) | (0<<TOIE0);
// External Interrupt(s) initialization
// INT0: Off
// Interrupt on any change on pins PCINT0-5: Off
GIMSK=(0<<INT0) | (0<<PCIE);
MCUCR=(0<<ISC01) | (0<<ISC00);
// USI initialization
// Mode: Disabled
// Clock source: Register & Counter=no clk.
// USI Counter Overflow Interrupt: Off
USICR=(0<<USISIE) | (0<<USIOIE) | (0<<USIWM1) | (0<<USIWM0) | (0<<USICS1) | (0<<USICS0) | (0<<USICLK) | (0<<USITC);
// Analog Comparator initialization
// Analog Comparator: Off
// The Analog Comparator's positive input is
// connected to the AIN0 pin
// The Analog Comparator's negative input is
// connected to the AIN1 pin
ACSR=(1<<ACD) | (0<<ACBG) | (0<<ACO) | (0<<ACI) | (0<<ACIE) | (0<<ACIS1) | (0<<ACIS0);
ADCSRB=(0<<ACME);
// Digital input buffer on AIN0: On
// Digital input buffer on AIN1: On
DIDR0=(0<<AIN0D) | (0<<AIN1D);
// ADC initialization
// ADC disabled
ADCSRA=(0<<ADEN) | (0<<ADSC) | (0<<ADATE) | (0<<ADIF) | (0<<ADIE) | (0<<ADPS2) | (0<<ADPS1) | (0<<ADPS0);
while (1)
      // Place your code here
         for(i = 0; i < 155; i++) {
            OCR1A = i;
            delay_ms(30);
         for(i = 154; i > 0; i--) {
            OCR1A = i;
            delay_ms(30);
  • Simulation Video.rar
Hello baileychic,
Great.
Let me tell you, if the i/p is analog signal between 0-5V then I am able to convert analog to digital and accordingly I am able to generate PWM of 100Hz.
Also I am able to vary duty according to the analog value.
Now my i/p is PWM signal. How to capture duty? according to captured duty, how to vary the o/p duty.
I am able to generate PWM of 100Hz at o/p but not able to capture the duty at i/p.
I need a code to capture the duty of i/p PWM.
I think the most reliable is from the manufacturer. ATMEL.COM, AVR135
I know how to use ICP with interrupts to find PWM duty. I also know how to generate 100 Hz PWM output but problem this ATTiny10 has only one Timer. So, still reading the datasheet to make the code.
there is a good chance that one timer can do both.
It depends on software and signal frequencies.
In Proteus ATTiny10 model is not working. I tested it with a Blinky example but it doesn't work. So, the code I make have to be tested on hardware.
It looks like ATtiny10 can be configured to use ICP and OCR simultaneously in timer normal mode. You have to figure out how.
I have figured it out and I have made the code but I am getting 50 Hz output PWM and not 100 Hz. I am trying to fix the code.
I have successfully made the code. Now it is giving 100 Hz PWM with duty according to input signal duty.
I am using ATtiny10. It has only 6 pins.
It has only one 16 bit timer. Does generation of PWM at o/p and capture of duty of i/p PWM possible by ATtiny10? (as it has only one timer).
I think it is possible because thats what I have done with ATMega8A (using one timer).
Hello baileychic,
Can you please send me the code. I would like to configure same for ATtiny10 controller.
Here is the code. It doesn't work for 0% duty and 100% duty PWM. It works fine for others on ATMega8A. Tested on hardware.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
Project : pwm2pwm
Version : 1.0.4
Date    : 8/24/2017
Author  :
Company :
Comments:
Chip type               : ATmega8
Program type            : Application
Memory model            : Small
Data Stack size         : 256
#include <io.h>
#include <stdio.h>
#include <string.h>
#include <delay.h>
// Alphanumeric LCD functions
#include <alcd.h>
#define SET   1
#define CLEAR 0
#define _LCD_COLUMN_LENGTH 16
char j = 0;
unsigned int current = 0, previous = 0, period = 0, width = 0;
unsigned char duty = 0;
unsigned int high_time = 1000;
unsigned int low_time = 250;
unsigned char state_counter = 0;
unsigned char do_calc = 0;
char txt[23];
// Timer1 input capture interrupt service routine
interrupt [TIM1_CAPT] void timer1_capt_isr(void)
    //if(do_calc == 0) {
        if(state_counter == 0) {
            current = ICR1;
            TCCR1B=(0<<ICNC1) | (0<<ICES1) | (0<<WGM13) | (0<<WGM12) | (0<<CS12) | (1<<CS11) | (1<<CS10);
            period = current - previous;
            previous = current;
            state_counter = 1;
        else if(state_counter == 1) {
            width = ICR1 - previous;
            TCCR1B=(0<<ICNC1) | (1<<ICES1) | (0<<WGM13) | (0<<WGM12) | (0<<CS12) | (1<<CS11) | (1<<CS10);
            state_counter = 0;
            //do_calc = 1;
// Timer1 output compare A interrupt service routine
interrupt [TIM1_COMPA] void timer1_compa_isr(void)
    static unsigned int last_reload;        //record of last value written to OCR1A
    static unsigned char output_mode;       //record of state of OCR1A output mode, 1 = set on compare, 0 = clear on compare
    if (output_mode) {
        //OCR mode is 'set on compare' so now set delay to high time and mode to clear on compare
        last_reload = last_reload + high_time;
        OCR1AH = last_reload >> 8;
        OCR1AL = last_reload & 0x00ff;
        TCCR1A=(1<<COM1A1) | (0<<COM1A0) | (0<<COM1B1) | (0<<COM1B0) | (0<<WGM11) | (0<<WGM10);
        output_mode = CLEAR;
    else {
        //OCR mode is 'clear on compare' so now set delay to low time and mode to set on compare
        last_reload = last_reload + low_time;
        TCCR1A=(1<<COM1A1) | (1<<COM1A0) | (0<<COM1B1) | (0<<COM1B0) | (0<<WGM11) | (0<<WGM10);
        output_mode = SET;
void main(void)
// Function: Bit7=Out Bit6=Out Bit5=Out Bit4=Out Bit3=Out Bit2=Out Bit1=Out Bit0=In
DDRB=(1<<DDB7) | (1<<DDB6) | (1<<DDB5) | (1<<DDB4) | (1<<DDB3) | (1<<DDB2) | (1<<DDB1) | (0<<DDB0);
// State: Bit7=0 Bit6=0 Bit5=0 Bit4=0 Bit3=0 Bit2=0 Bit1=0 Bit0=P
PORTB=(0<<PORTB7) | (0<<PORTB6) | (0<<PORTB5) | (0<<PORTB4) | (0<<PORTB3) | (0<<PORTB2) | (0<<PORTB1) | (1<<PORTB0);
// Port C initialization
// Function: Bit6=In Bit5=Out Bit4=Out Bit3=Out Bit2=Out Bit1=Out Bit0=Out
DDRC=(0<<DDC6) | (1<<DDC5) | (1<<DDC4) | (1<<DDC3) | (1<<DDC2) | (1<<DDC1) | (1<<DDC0);
// State: Bit6=P Bit5=0 Bit4=0 Bit3=0 Bit2=0 Bit1=0 Bit0=0
PORTC=(1<<PORTC6) | (0<<PORTC5) | (0<<PORTC4) | (0<<PORTC3) | (0<<PORTC2) | (0<<PORTC1) | (0<<PORTC0);
// Port D initialization
// Function: Bit7=Out Bit6=Out Bit5=Out Bit4=Out Bit3=Out Bit2=Out Bit1=Out Bit0=Out
DDRD=(1<<DDD7) | (1<<DDD6) | (1<<DDD5) | (1<<DDD4) | (1<<DDD3) | (1<<DDD2) | (1<<DDD1) | (1<<DDD0);
// State: Bit7=0 Bit6=0 Bit5=0 Bit4=0 Bit3=0 Bit2=0 Bit1=0 Bit0=0
PORTD=(0<<PORTD7) | (0<<PORTD6) | (0<<PORTD5) | (0<<PORTD4) | (0<<PORTD3) | (0<<PORTD2) | (0<<PORTD1) | (0<<PORTD0);
TCCR0=(0<<CS02) | (0<<CS01) | (0<<CS00);
TCNT0=0x00;
// Clock value: 125.000 kHz
// Mode: Normal top=0xFFFF
// OC1A output: Toggle on compare match
// Noise Canceler: Off
// Input Capture on Rising Edge
// Timer Period: 0.52429 s
// Output Pulse(s):
// OC1A Period: 1.0486 s Width: 0.52429 s
// Input Capture Interrupt: On
// Compare A Match Interrupt: On
TCCR1A=(0<<COM1A1) | (1<<COM1A0) | (0<<COM1B1) | (0<<COM1B0) | (0<<WGM11) | (0<<WGM10);
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer2 Stopped
// OC2 output: Disconnected
ASSR=0<<AS2;
TCCR2=(0<<PWM2) | (0<<COM21) | (0<<COM20) | (0<<CTC2) | (0<<CS22) | (0<<CS21) | (0<<CS20);
TCNT2=0x00;
OCR2=0x00;
TIMSK=(0<<OCIE2) | (0<<TOIE2) | (1<<TICIE1) | (1<<OCIE1A) | (0<<OCIE1B) | (0<<TOIE1) | (0<<TOIE0);
// INT0: Off
// INT1: Off
MCUCR=(0<<ISC11) | (0<<ISC10) | (0<<ISC01) | (0<<ISC00);
// USART initialization
// USART disabled
UCSRB=(0<<RXCIE) | (0<<TXCIE) | (0<<UDRIE) | (0<<RXEN) | (0<<TXEN) | (0<<UCSZ2) | (0<<RXB8) | (0<<TXB8);
ACSR=(1<<ACD) | (0<<ACBG) | (0<<ACO) | (0<<ACI) | (0<<ACIE) | (0<<ACIC) | (0<<ACIS1) | (0<<ACIS0);
SFIOR=(0<<ACME);
// ADC disabled
ADCSRA=(0<<ADEN) | (0<<ADSC) | (0<<ADFR) | (0<<ADIF) | (0<<ADIE) | (0<<ADPS2) | (0<<ADPS1) | (0<<ADPS0);
// SPI initialization
// SPI disabled
SPCR=(0<<SPIE) | (0<<SPE) | (0<<DORD) | (0<<MSTR) | (0<<CPOL) | (0<<CPHA) | (0<<SPR1) | (0<<SPR0);
// TWI initialization
// TWI disabled
TWCR=(0<<TWEA) | (0<<TWSTA) | (0<<TWSTO) | (0<<TWEN) | (0<<TWIE);
// Alphanumeric LCD initialization
// Connections are specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTC Bit 0
// RD - PORTD Bit 0
// EN - PORTC Bit 1
// D4 - PORTC Bit 2
// D5 - PORTC Bit 3
// D6 - PORTC Bit 4
// D7 - PORTC Bit 5
// Characters/line: 16
lcd_init(16);
lcd_gotoxy(1,0);
lcd_puts("    PWM Duty    ");
// Globally enable interrupts
#asm("sei")
  while (1)
        // Place your code here        j
        sprintf((char *)txt, "%3u", duty);
        strcat(txt, "%");
        j = ((_LCD_COLUMN_LENGTH / 2) - (strlen(txt) / 2));
        strcat(txt, "  ");
        lcd_gotoxy(j,1);
        lcd_puts(txt);
        //if(do_calc == 1) {
           duty = (unsigned char)((float)(((float)width / (float)period) * 100.0));
           high_time = (unsigned int)duty * 10;
           low_time = 1250 - high_time;
           do_calc = 0;
Hello baileychic ,
Thanks for the code. I appreciate your work.
Can you please do one more favor for me. I was trying to implement the same code for ATtiny10, but I got so many errors while doing the same.
Can you please help me with ATtiny 10 code. I don't need LCD and other functioning. I need to generate 100Hz frequency at o/p with duty cycle is equal to the i/p duty cycle using single timer.
Please help me. Only this will get success to my project.
Awaiting for positive reply.
Don't waste your time with ATTiny10. I made ATTiny10 code but it doesn't compile due to insufficient RAM. Better choose a different ATTiny chip.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
Project : PWM2PWM
Version : 1.0.0
Date    : 9/25/2017
Author  : bailychic
Company : NA
Comments:
Chip type               : ATtiny10
Memory model            : Tiny
Data Stack size         : 8
#include <io.h>
#define SET   1
#define CLEAR 0
// Timer 0 input capture interrupt service routine
interrupt [TIM0_CAPT] void timer0_capt_isr(void)
    if(do_calc == 0) {
            current = ICR0;
            previous = current;
            state_counter = 1;
            TCCR0B=(0<<ICNC0) | (0<<ICES0) | (0<<WGM03) | (0<<WGM02) | (0<<CS02) | (1<<CS01) | (1<<CS00);
            width = ICR0 - previous;
            TCCR0B=(0<<ICNC0) | (1<<ICES0) | (0<<WGM03) | (0<<WGM02) | (0<<CS02) | (1<<CS01) | (1<<CS00);
            state_counter = 0;
            do_calc = 1;
// Timer 0 output compare A interrupt service routine
interrupt [TIM0_COMPA] void timer0_compa_isr(void)
    if (output_mode) {
        OCR0AH = last_reload >> 8;
        OCR0AL = last_reload & 0x00ff;
        TCCR0A=(0<<COM0A1) | (0<<COM0A0) | (0<<COM0B1) | (0<<COM0B0) | (0<<WGM01) | (0<<WGM00);
    else {
        TCCR0A=(0<<COM0A1) | (1<<COM0A0) | (0<<COM0B1) | (0<<COM0B0) | (0<<WGM01) | (0<<WGM00);
        output_mode = SET;
void main(void)
// Main Clock source: Calibrated Internal 8 MHz Osc.
CCP=0xd8;
CLKMSR=(0<<CLKMS1) | (0<<CLKMS0);
// Clock Prescaler division factor: 1
CCP=0xd8;
CLKPSR=(0<<CLKPS3) | (0<<CLKPS2) | (0<<CLKPS1) | (0<<CLKPS0);
// Voltage Level Monitor initialization
// Trigger Level: Voltage Level Monitor Disabled
// Interrupt: Off
VLMCSR=(0<<VLMF) | (0<<VLMIE) | (0<<VLM2) | (0<<VLM1) | (0<<VLM0);
// Pull-up initialization:
// Bit3=Off Bit2=Off Bit1=On Bit0=Off
PUEB=(0<<PUEB3) | (0<<PUEB2) | (1<<PUEB1) | (0<<PUEB0);
// Function: Bit3=Out Bit2=Out Bit1=In Bit0=Out
DDRB=(1<<DDB3) | (1<<DDB2) | (0<<DDB1) | (1<<DDB0);
// State: Bit3=0 Bit2=0 Bit1=P Bit0=0
PORTB=(0<<PORTB3) | (0<<PORTB2) | (1<<PORTB1) | (0<<PORTB0);
// Break Before Make Mode PORTB: Off
PORTCR=(0<<BBMB);
// Input Capture Noise Canceler: Off
// OC0A output: Toggle on compare match
// Output Pulse(s):
// OC0A Period: 1.0486 s Width: 0.52429 s
TCNT0=0x0000;
ICR0=0x0000;
OCR0A=0x0000;
OCR0B=0x0000;
// Timer/Counter 0 Interrupt(s) initialization
TIMSK0=(1<<ICIE0) | (0<<OCIE0B) | (1<<OCIE0A) | (0<<TOIE0);
// INT0: Off
// Interrupt on any change on pins PCINT0-3: Off
EICRA=(0<<ISC01) | (0<<ISC00);
EIMSK=(0<<INT0);
PCICR=(0<<PCIE0);
ACSR=(1<<ACD) | (0<<ACO) | (0<<ACI) | (0<<ACIE) | (0<<ACIC) | (0<<ACIS1) | (0<<ACIS0);
DIDR0=(0<<ADC0D) | (0<<ADC1D);
// ADC disabled
#asm("sei")
while (1)
        if(do_calc == 1) {
           do_calc = 0;
Hello baileychic,
I have implemented the same code you gave for the ATTINY10. I am not getting any issue of code size.
I am getting different errors. Please suggest.
Severity Code Description Line
Error recipe for target 'main.o' failed 76
Error 'TIM0_CAPT' undeclared here (not in a function) 25
Error expected '=', ',', ';', 'asm' or '__attribute__' before 'void' 25
Error 'TIM0_COMPA' undeclared here (not in a function) 47
Error expected '=', ',', ';', 'asm' or '__attribute__' before 'void' 47
Error invalid preprocessing directive #asm 145
