[SOLVED] Pspice: 2 switch forward converter (double-ended"
chemavecino
Newbie level 3
Newbie level 3
Hi everyone,
Im trying to simulate this converter but there is something wrong with my circuit.
I am not sure if it is the circuit itself or maybe the values. I dont need it to work with any specific values, I just need to check the wave forms.
Here is my circuit:
Please someone take a look, it is probably an obvious thing but I can't figure it out.
I attached the pspice files.
Thank you
  • Trabajo_2.zip
You have one vpulse source inverted which is completely wrong. Both switches have to be controlled simultaneously, you can simply use one vpulse source for both switches.
Thank you for your answer. That was a pretty dumb mistake, I didn't realize.
Well now I've changed my circuit as you said. The simulation is interrupted and I need to click on "autoconverge" in order to resume the simulation.
Now the current on L3 seems to be right, but not the current on L4 or the Vout, is there anything else wrong?
Thank you
