Protel problem when making multiple small PCBs on bigger one
Robby
Member level 2
Member level 2
Pro*tel Problem
Hello,
following problem occours if pr*tel is used to create multiple small pcb's on
a greater one.
The single small one was created as usual. Then this one was placed using
paste special (there are some options in contrast to ordinary paste) on the target board.
Now the following happens: The original small one, originally overcast by a polygon plane
for copper contain the dead share copper originally removed, again.
No option I have discovered works. Why does this happen?
If somebody know a solution, it'd be fine. 8O
thanks
Robby
