bianca_p
Hi , I'm trying to make a digital circuit that implements a 5-bit Gray code counter with priority reset. I've tried simulating the circuit on ISP lever Classic Project and doesn't work.I have to use GALp16v8
I have the following errors:
Input file: 'gray.tt2'
Device 'p16v8'
Note 4161: Using device architecture type P16V8R.
Warning 4034:Unable to preserve preassignments - performing second pass without preassignments.
Note 4059: Signal Q0 cannot be assigned (to pin 16) because
there are too many terms for output Q0 pin 16.
Note 4046: Signal Q1 (which has no OE) has been
assigned to pin 15 (which has pin OE).
Note 4046: Signal Q2 (which has no OE) has been
assigned to pin 14 (which has pin OE).
Note 4046: Signal Q3 (which has no OE) has been
assigned to pin 13 (which has pin OE).
Note 4046: Signal Q4 (which has no OE) has been
assigned to pin 12 (which has pin OE).
Design does NOT fit
FIT complete. Time: 1 second.
Done: failed with exit code: 0001.
Device 'p16v8'
Design does NOT fit
MODULE Numarator_Gray
TITLE 'Numarator_Gray_5_biti'
declarations
clock,reset pin 1,2;
Y pin 3;
Q0,Q1,Q2,Q3,Q4 pin 14,15,16,17,18 istype 'reg';
"definitiile starilor
QSTATE=[Q4,Q3,Q2,Q1,Q0];
S0=[0,0,0,0,0];
S1=[0,0,0,0,1];
S2=[0,0,0,1,1];
S3=[0,0,0,1,0];
S4=[0,0,1,1,0];
S5=[0,0,1,1,1];
S6=[0,0,1,0,1];
S7=[0,0,1,0,0];
S8=[0,1,1,0,0];
S9=[0,1,1,0,1];
S10=[0,1,1,1,1];
S11=[0,1,1,1,0];
S12=[0,1,0,1,0];
S13=[0,1,0,1,1];
S14=[0,1,0,0,1];
S15=[0,1,0,0,0];
S16=[1,1,0,0,0];
S17=[1,1,0,0,1];
S18=[1,1,0,1,1];
S19=[1,1,0,1,0];
S20=[1,1,1,1,0];
S21=[1,1,1,1,1];
S22=[1,1,1,0,1];
S23=[1,1,1,0,0];
S24=[1,0,1,0,0];
S25=[1,0,1,0,1];
S26=[1,0,1,1,1];
S27=[1,0,1,1,0];
S28=[1,0,0,1,0];
S29=[1,0,0,1,1];
S30=[1,0,0,0,1];
S31=[1,0,0,0,0];
equations
@dcset;
QSTATE.clk=clock;
when ( Y==1 ) then {
when (reset == 0) then QSTATE := S0;
else when (QSTATE == S0) THEN QSTATE := S1;
else when (QSTATE == S1) THEN QSTATE := S2;
else when (QSTATE == S2) THEN QSTATE := S3;
else when (QSTATE == S3) THEN QSTATE := S4;
else when (QSTATE == S4) THEN QSTATE := S5;
else when (QSTATE == S5) THEN QSTATE := S6;
else when (QSTATE == S6) THEN QSTATE := S7;
else when (QSTATE == S7) THEN QSTATE := S8;
else when (QSTATE == S8) THEN QSTATE := S9;
else when (QSTATE == S9) THEN QSTATE := S10;
else when (QSTATE == S10) THEN QSTATE := S11;
else when (QSTATE == S11) THEN QSTATE := S12;
else when (QSTATE == S12) THEN QSTATE := S13;
else when (QSTATE == S13) THEN QSTATE := S14;
else when (QSTATE == S14) THEN QSTATE := S15;
else when (QSTATE == S15) THEN QSTATE := S16;
else when (QSTATE == S16) THEN QSTATE := S17;
else when (QSTATE == S17) THEN QSTATE := S18;
else when (QSTATE == S18) THEN QSTATE := S19;
else when (QSTATE == S19) THEN QSTATE := S20;
else when (QSTATE == S20) THEN QSTATE := S21;
else when (QSTATE == S21) THEN QSTATE := S22;
else when (QSTATE == S22) THEN QSTATE := S23;
else when (QSTATE == S23) THEN QSTATE := S24;
else when (QSTATE == S24) THEN QSTATE := S25;
else when (QSTATE == S25) THEN QSTATE := S26;
else when (QSTATE == S26) THEN QSTATE := S27;
else when (QSTATE == S27) THEN QSTATE := S28;
else when (QSTATE == S28) THEN QSTATE := S29;
else when (QSTATE == S29) THEN QSTATE := S30;
else when (QSTATE == S30) THEN QSTATE := S31;
else when (QSTATE == S31) THEN QSTATE := S0;
else
else when (QSTATE == S0) THEN QSTATE := S31;
else when (QSTATE == S31) THEN QSTATE := S30;
else when (QSTATE == S30) THEN QSTATE := S29;
else when (QSTATE == S29) THEN QSTATE := S28;
else when (QSTATE == S28) THEN QSTATE := S27;
else when (QSTATE == S27) THEN QSTATE := S26;
else when (QSTATE == S26) THEN QSTATE := S25;
else when (QSTATE == S25) THEN QSTATE := S24;
else when (QSTATE == S24) THEN QSTATE := S23;
else when (QSTATE == S23) THEN QSTATE := S22;
else when (QSTATE == S22) THEN QSTATE := S21;
else when (QSTATE == S21) THEN QSTATE := S20;
else when (QSTATE == S20) THEN QSTATE := S19;
else when (QSTATE == S19) THEN QSTATE := S18;
else when (QSTATE == S18) THEN QSTATE := S17;
else when (QSTATE == S17) THEN QSTATE := S16;
else when (QSTATE == S16) THEN QSTATE := S15;
else when (QSTATE == S15) THEN QSTATE := S14;
else when (QSTATE == S14) THEN QSTATE := S13;
else when (QSTATE == S13) THEN QSTATE := S12;
else when (QSTATE == S12) THEN QSTATE := S11;
else when (QSTATE == S11) THEN QSTATE := S10;
else when (QSTATE == S10) THEN QSTATE := S9;
else when (QSTATE == S9) THEN QSTATE := S8;
else when (QSTATE == S8) THEN QSTATE := S7;
else when (QSTATE == S7) THEN QSTATE := S6;
else when (QSTATE == S6) THEN QSTATE := S5;
else when (QSTATE == S5) THEN QSTATE := S4;
else when (QSTATE == S4) THEN QSTATE := S3;
else when (QSTATE == S3) THEN QSTATE := S2;
else when (QSTATE == S2) THEN QSTATE := S1;
else when (QSTATE == S1) THEN QSTATE := S0;
Test_Vectors ([reset,clock,Y]->[Q4,Q3,Q2,Q1,Q0])
[0, .c., .x.]->[0,0,0,0,0];
[1, .c., 1 ]->[0,0,0,0,1];
[1, .c., 1 ]->[0,0,0,1,1];
[1, .c., 1 ]->[0,0,0,1,0];
[1, .c., 1 ]->[0,0,1,1,0];
[1, .c., 1 ]->[0,0,1,1,1];
[1, .c., 1 ]->[0,0,1,0,1];
[1, .c., 1 ]->[0,0,1,0,0];
[1, .c., 1 ]->[0,1,1,0,0];
[1, .c., 1 ]->[0,1,1,0,1];
[1, .c., 1 ]->[0,1,1,1,1];
[1, .c., 1 ]->[0,1,1,1,0];
[1, .c., 1 ]->[0,1,0,1,0];
[1, .c., 1 ]->[0,1,0,1,1];
[1, .c., 1 ]->[0,1,0,0,1];
[1, .c., 1 ]->[0,1,0,0,0];
[1, .c., 1 ]->[1,1,0,0,0];
[1, .c., 1 ]->[1,1,0,0,1];
[1, .c., 1 ]->[1,1,0,1,1];
[1, .c., 1 ]->[1,1,0,1,0];
[1, .c., 1 ]->[1,1,1,1,0];
[1, .c., 1 ]->[1,1,1,1,1];
[1, .c., 1 ]->[1,1,1,0,1];
[1, .c., 1 ]->[1,1,1,0,0];
[1, .c., 1 ]->[1,0,1,0,0];
[1, .c., 1 ]->[1,0,1,0,1];
[1, .c., 1 ]->[1,0,1,1,1];
[1, .c., 1 ]->[1,0,1,1,0];
[1, .c., 1 ]->[1,0,0,1,0];
[1, .c., 1 ]->[1,0,0,1,1];
[1, .c., 1 ]->[1,0,0,0,1];
[1, .c., 1 ]->[1,0,0,0,0];
END
