[PIC] Program halted after some time (around 100 seconds)
urnuj
Junior Member level 3
Hi
The MCU is pic33ep512MU814 and it is being compiled and debugged using MPLABX and XC-16.
I have set it up in a while loop with a timer interrupt to handle some processes.
The program is able to run normally when it is being debugged but it is halted due to a break in user code after 100 over seconds.
Is there a reason that it is not able to continue running and being caused to stop?
Regards
hello,
it can stop because
- Watchdog armed and time elapsed without CLRWDT ...
- RAM area table overwrite
not enough size of element in RAM Table assigned to a variable
example : size of ascci char used with float to ascii conversion
- branc error in the program wich can occurs after n iterations
- to much subroutines imbrication => stack overflow
- to weak battery.. restet by under voltage
your source must be analysed in detail to have a more precise idea.
Check if you hare next to the limit of RAM and ROM amount used by your application
Add TRACE information to find out where you get stop.
Reactions: urnuj
    urnuj
Use reset cause register and error exception code to narrow down the problem.
Reactions: urnuj
    urnuj
Ok. I shall try and narrow it down and see what is causing the problem.
I am guessing it could be memory overun as it is happening at the same time always.
Regards
