processing .bmp file using verilog testbench
pforpashya
Member level 2
जगा व जगू द्या
can some body give me idea how to read .bmp file using a verilog testbench & a 32 bit register & again we have to dump this image after reading from testbench..
thank you......
maybe convert the bmp from a binary to an hexadecimal represented ascii file, and then read it into verilog with $readmemh. Use google to find a utility.
The ASCII file may require massaging via a Perl script to get it into a format that verilog can parse.
Hi pforpashya,
You can do it like this:
module test;
  integer fileId, i;
  reg [7:0]  aaa [0:1000];
  initial begin
    // Read
    fileId = $fopen("mypicIn.bmp", "rb");
    $fread(aaa, fileId);
    for(i = 0; i < 1000; i = i + 1)
      $display("%h",aaa[i]);
    $fclose(fileId);
  end
endmodule
But this is verilog 2k feature. So don't forget to enable v2k.
Best Regards,
Tiksan
http://syswip.com/
