I am working on a project using PIC 16F877A.Part of the duties of the chip is controlling the speed of several fans using the two PWM outputs.
At first everything worked fine.Then (after two months) the outputs failed, producing some funny signals.At first I was puzzled,but then I programmed the device again and everything was fine.
Until recently.Now even the programming doesn't help and I have no idea what the problem might be.I am sure the program itself is OK.
The programmer is JDM,the software is IC-prog.
Do you have any idea as to what might have happened?
Thank you.
