[SOLVED] problem with transistor model d flip flop
diaz080
Member level 4
friends..i'ma beginner to cadence.. last day i tried to implement pose edge d flip flop using transistors(logic gates). Now i'm facing a problem.The circuit is passing data line on both edge of the clock. Can anybody help me to figure out what went wrong with this circuit design
Question: Your schematic has NAND gates which have 3 inputs. I wonder what the simulator does about those unused inputs? Are they recognized as high or low?
Likewise, what level are you applying to the D (Data) inputs?
Falstad's simulator comes with a similar flip-flop. The Nand gates are all 2-input. The scope traces show how it is supposed to function.
3rd input is active low set & reset..i'm applying a pulse to the d line
It looks roughly right to me, only the action is on the
negative clock edge. By eye it looks like Ck/ catches
the right state of d into q.
@dick_freebird nope.it is happening in both edges. i think i figured out the problem. Problem was with the sizing of the logic gates which i used . Now it is working correctly. thanks guys
Yes, looks like the unwanted negative edge action is due to irregular timing, slave stage is deactivated too late.
