zezito
Newbie level 3
Big Problem!!
I have a big problem!!
There is a rectifier (IN 380V ; OUT 20V 50A without a transf.) connected to an anodizing cube. when start to raise the voltage, the current strats to flow thru the bath when the voltage reaches +- 10V!
Now the problem is how to make the current flow thru the bath with less voltage??
I attached a file so that you can see what i think it will solution this problem, but please write your opinion!!!
Thank you all
Thank you all
