neoflash
Advanced Member level 1
In a lecture on ADC converter, lecturer stated that in pipeline ADC, if previous stage’s non-ideality induces significant extra quantization noise, next stage suffer missing code issue.
Below graph illustrated this problem, Y-axis is the residue of 1st stage ADC, as we see, the extra residue (red curve) will overload next stage, such that induced more error.
Lecturer stated that this will incur missing code issue. She ascribed the reason to the extra residue overload 2nd stage, so she suggested a kind of cure to lower the gain between 1st and 2nd stage, so that the "long" residue will be shorter.
However, I understand it differently. The missing code is induced not by the extra quantization noise. It is not coming from the “long” residue, instead, it is caused by the “short” residue curve. The short residue might not be able to cover all codes in 2nd stage, thus induce the missing code.
If my understanding is right, thus lowering the gain will not cure the problem, instead, it will make things worse since it make the short residue shorter, am I right?
