godfreyl
Re: problem with regulator
Yes, but the resistor burned, so there was obviously more than 1.25V across it. That means the regulator wasn't working properly. It also means the high current that burned R1 was also flowing through the pot, as there's no other path for it.R2 can't create this problem, even if it is set to 0 the output voltage will be still be 1.25v , the voltage across R1 will be equal to Vref (1.25v) while the regulator is operating properly....
