thebadtall
Full Member level 6
hello, i have a problem with lm317 adjustable regulator.
when i supply it with 12vdc it is fine,and adjustable down to 1,5v
but when i supply it with 35vdc and trying to adjust it drops only down to 34.5 and the 220ohm resistor (adjust - out ) burns and smokes.
the circuit is the test circuit of the datasheet
the capacitors are 50v rated
the psu are both smps
thank you
thank you
