#include<pic.h> //Define PIC Registers
#include<stdio.h>
__CONFIG(0x3f72); //Select HS oscillator, Enable (PWRTE,BOREN),
//Disable (CPD,CP,WDTEN,In-circuit Debugger
#define LC01CTRLIN 0xd0
#define LC01CTRLOUT 0xd1
#define I2C_FREG 100
#define FOSC 10000
#define BAUD_RATE 9.6 // 9600 Baud rate
#define BAUD_VAL (char)(FOSC/ (16 * BAUD_RATE )) - 1;
//Calculation For 9600 Baudrate @10Mhz
unsigned char sec,min,hour,day,date,month,year;
unsigned char data[7]={0x45,0x59,0x71,0x04,0x05,0x10,0x06};
int i;
void DS1307Write(unsigned char,unsigned char);
void WaitMSSP();
unsigned char DS1307Read(unsigned char);
void i2c_init(void);
void ds1307_init(void);
void serial_init(void);
void DelayMs(unsigned int);
void main()
int count=0;
DelayMs(20);
ds1307_init();
serial_init();
for(i=0;i<7;i++)
DS1307Write(i,data[i]);
printf("\033[2J");
DelayMs(20);
while(1)
sec=DS1307Read(0); // Read second
min=DS1307Read(1); // Read minute
hour=DS1307Read(2); // Read hour
day=DS1307Read(3); // Read day
date=DS1307Read(4); // Read date
month=DS1307Read(5); // Read month
year=DS1307Read(6); // Read year
printf("Time: %x : %x : %x ",(hour&0x1f),min,sec); //Display the Hours, Minutes, Seconds(hours is taken from 5 LSB bits
printf("Date: %x / %x / %x \r",date,month,year); //Display the Date, Month, Year
DelayMs(150);
void DS1307Write(unsigned char addr, unsigned char data)
SEN=1; //Initiate Start condition on SDA & SCL pins
WaitMSSP();
SSPBUF=LC01CTRLIN; // Slave address + Write command
WaitMSSP();
SSPBUF=addr; // Write the location
WaitMSSP();
SSPBUF=data; // Write the Data
WaitMSSP();
PEN=1; // Enable the Stop bit
WaitMSSP();
unsigned char DS1307Read(unsigned char addr)
unsigned char x;
RSEN=1; // Enable the repeated Start Condition
WaitMSSP ();
WaitMSSP ();
SSPBUF=addr;
//Write the location (memory address of Hour, minute, etc...
WaitMSSP ();
WaitMSSP ();
SSPBUF=LC01CTRLOUT; // Slave address + Read command
WaitMSSP ();
RCEN=1; // Enable to receive data
WaitMSSP ();
ACKDT=1; // Acknowledge the operation (Send NACK)
ACKEN=1; // Acknowledge sequence on SDA & SCL pins
WaitMSSP ();
x=SSPBUF; // Store the Receive value in a variable
return (x);
void WaitMSSP()
while(!SSPIF); // SSPIF is zero while TXion is progress
SSPIF=0;
void ds1307_init()
TRISC3=1; // RC3,RC4 set to I2C Mode(Input)
TRISC4=1;
SSPCON=0x28; // Enable the SDA,SCL & I2C Master Mode
SSPADD=(FOSC / (4 * I2C_FREG)) - 1;// SSP baud rate 100Khz
SSPSTAT=0x80; // Disable slew Rate control
PORTC=0x18;
DS1307Write(0,0x00);
void serial_init()
TRISC6=1; // RC7, RC6 set to USART Mode
TRISC7=1;
TXSTA=0x24;
// Enable Transmission, Asynchronous mode, High Speed mode
SPBRG=BAUD_VAL; // 9600 Baud rate selection
RCSTA=0x90; // Enable Serial Port & Continuous Reception
TXIF=1; // Enable Transmission
void putch(unsigned char byte)//Required for printf statement
while(!TXIF); // Wait for the Transmit Buffer to be empty
TXREG = byte; // Transmit the Data
void DelayMs(unsigned int Ms)
int delay_cnst;
while(Ms>0)
Ms--;
for(delay_cnst = 0;delay_cnst <220;delay_cnst++);
