Solar88
Hi. Someone had told me the parameters of my solar panel and 12V 44Ah battery were compatible with the CMP12/24 charger controller.
The params of my solar panel: 24V 3.6A
I recently bought this charger controller. So, I connected the battery first then the solar panel and finally customer to the charger controller. It actually has worked fine for about 1 month. After this time the charger controller went wrong. I could measure 15,6V on the battery!
Plus, I do not really see why its output keeps changing from Low level to High level??:-?
According to the tests all the 3x3205 N channel MOSFETs seems to be good. :-(
Could you please help me with this problem?
Cheers, Solar88
Cheers, Solar88
