Almost nobody will download the file to check and/or simulate.
I think you would better to caption your circuit schematic and simulation results that worries you as well.
If you encounter problems in screen capturing, you can use this command from terminal:
xwd -out screenshot.xwd -root
gimp screenshot.xwd
Type: >>
man xwd for more details about that command.
Also these links will help you in shaa allaah:
http://tips.webdesign10.com/how-to-take-a-screenshot-on-ubuntu-linux
And this is to make a bindkey for snapshot command:
http://docs.kde.org/development/en/kdebase/userguide/keys-for-scripts.html
Regarding your design, you're designing a bias circuit or band-gap reference.. There're a lot of technical papers that can help u. Check .
If you want to build a band-gap reference current, First build a standard 1.2v output BGR then generate current through a resistor. Dumping voltage to current on such resistor is critical, so that resistor should be very accurately and precisely made, usually it's done off-chip. i.e. you'll put a pin for off-chip connection.
I hope that helps
Regards,
Ahmad,
