Problem with awr mwo simulation
miky
Newbie level 6
Hello
I'm trying to simulate an antenna that I have found on the internet. I'm trying to get the same values for it withe Microwave, but it dosen't work very well.
I put my settings in the rar file and I hope someone could take a look and give me some feedback where my misstakes are.
Regards,
Miky
  • Near-field RFID.rar
  • Near-field RFID.pdf
Hello Miky,
It looks your EM Structure dimensions totally different as compared to article values such as W, S...
Example for W you used 1mm where as in article it is mentioned as 2mm, & also some of the length values are different...
Once these are set you are going to get exact results....
Also I observed that you have not added the explicit Ground Plane for this structure this is the main cause for different results....
---manju---
Yes, the explicit ground plane is missing, I think this is the most important difference.
