Problem with ADC interfacing!!
Tamasco
Full Member level 3
Full Member level 3
Hi Everyone !!
I simulated an 8051 with an ADC8004 but got some unexpected results. The following is the schematic. For simplicity, I output the result to leds. The output is the same irrespective of the value of Vin!
The following is the assembly code :
Org 0h
start:
mov A,P2 ; save ADC data to Accumulator
mov P3, A ; output data
sjmp start
end
What could be this problem?
I would indeed be very grateful for your input. Thanks in advance.
Hi Tamasco
Even if ADC is running continuously you still need an initializing pulse following power-up. The WR and INTR node should be momentarily forced to logic low following a power-up cycle to guarantee operation.
    Tamasco
here my code! Hope it help full to you
#include "REG52.H"
sbit INT = P3^3;
sbit RW  = P3^2;  //edge L->H (canh len) cho phep analog signal vao ADC _bat dau chuyen doi
sbit READ  = P3^1;//doc data tu ADC0804 edge H->L (tac dong canh xuong)
sbit CS  =  P3^0;
void delay(unsigned char i);
void main(void)
IE=0x84;//cho phep ngat ngoai 1 o chan P3.3
IT0=1;//cho phep ngat canh xuong
P2=0xFF;
P3=0xFF;
//cho phep ADC hoat dong
CS=0;
//RW tac dong canh len => bat dau cuyen doi
//start covert
RW=0;
RW=1;
while(1);
//============interupt================
void ADC_READY(void) interrupt 2
{unsigned char temp;
EX1=0;//cam ngat ngoài 1
//Read tac dong canh xuong cho phep doc digital
READ=1;
READ=0;
EX1=1;//cho phep ngat
//bat dau chuyen doi
RW=0;
RW=1;
// ==========sub================
while(i--)
{ unsigned char k=121;
while(k--);
[/quote]
    Tamasco
Thank you very much, Silvio and baocr!!
I'll reconfigure it.
see this link and use the same hardware logic
Bibin john
www.bibinjohn.tk
