I'm new to HFSS, and I want to EM simulate the ind_std model in Cadence Virtuso using it. I've imported the .gds file and set up a driven modal solution type, but I'm confused about assigning boundaries and excitations. I have already desgined an inductor from scratch using tutorials I've found online, but my problem is the imported model. How should I set up the boundaries and excitation ports? What kind of boundary or port should I use?
Also, the imported gds file looks 2D, and I'm not sure whether it's fine. Was I supposed to add a layer map or technology file or something to make it look 3D?
I'm also not sure about the efficiency of HFSS in my case. I've read that HFSS creates a large number of meshes which is not suitable to simulate RF inductors, and it seems reasonable as it took the gds file so long to be imported and validated. Should I give up on HFSS and use something else such as Moemntum or Sonnet? Which is better in my case?
Thanks a lot.
(P.S: My inductors are needed for the Ka band, of a typical range of 50-200pH)
