Problem Regarding Reflector Coefficient
@YY
Member level 2
Since the reflector coefficient, Γ which shown in the VNA was in dB form. If I wanna look for the Zin by using the smith chart, I wonder is the Γ value is in normalize form or not. Can we directly apply the Γ in the smith chart to find the Zin?
tyassin
Advanced Member level 1
Hi
It is NOT in normalised form.
Yes you can find the input impedance for small-signal.
Regards
@YY
Member level 2
if it's not in normalize form, then should we convert it into normalize form before we apply into the smith chart?
tyassin
Hi
Yes that is correct
Kohi_boy
Full Member level 4
Reflector coefficient in dB. Are you referring to S11 ?
If so, you can change S11 to r (in Mag and Phase).
Given Mag and Phase of r, you should be able to plot in the smith chart and obtain the normalise Zin from the chart.
Chinaski
Spain
Push the FORMAT button on your VNA front panel and change to Smith Chart. It's the easy way. Nevertheless, try to study harder before using a VNA (it's a very expensive toy to play with)
