Problem Processing the adc value in 8051
thannara123
India
ADC is working output is shown in bar LED . and the data is given to the Port - P1.
And again the Port 1 vaule is given to the Port 3 ( just for testing )
nothing showing ..
please help me ?
#include <REGX51.H>
#include "lcd.h"
#include "adc.h"
void main(){  unsigned char a = 0;
P2 =0x00;
P0 =0x00;
P1 = 0xff;
P3 = 0x00;
lcd_init();
lcd_cmd(0x80);
lcd_data(54);     // just send "1" to lcd to display ;
string("t");
lcd_cmd(0xc0);
conv(); //Start conversion
read(); //Read ADC
  P3 = P1;
lcd_data(a);
while(1);
Proteus file attached .
  • adc.rar
Re: ADC is working but cant processes the adc value in 8051
sir ignore that
// a = 48 + P1;
yes P1 the adc data port connected .
is and assigned to P3 = P1;
If i give ADC input as 5 volt the all LED blinks ,that means the adc output are correct , but the data is not came at the 8051 P1 port . why so
how to make a port as input
P1 = 0xff ?
what is the wrong with me ?
I think the voltage from the ADC is too low ?
when I give an extra 5 volt to some of the port of the P1 ,gives the value to P3 ( ie working )
how can i rectify ?
please help me ?
yes I uploaded the proteus file ?
I dont connected Vref/2 . step size considered as 19.53 (just for testing )
But i can get the correct value from adc ?
INTR is used in conv() or read(). Post full code.
Put
Code C - [expand]
conv() and read()
and also lcd display functions inside while(1) loop. According to your code you are reading adc once and displaying once. After that if adc value changes you are not updating.
#define cs P0_0
#define rd P0_1
#define wr P0_2
#define intr P0_3
void conv(); //Start of conversion function
void read(); //Read ADC function
unsigned char adc_val;
void conv() {
cs = 0; //Make CS low
wr = 0; //Make WR low
wr = 1; //Make WR high
cs = 1; //Make CS high
while (intr); //Wait for INTR to go low
void read() {
rd = 1; //Make RD low
 adc_val = P1;
rd = 0; //Make RD high
Now gets the value at pin P1 and can be assigned in P3
P3 = P1;
But it shows only in 1 MHZ frequency .
anybody help me ?
Yes .i tried with diffrent crystal code as a debug ...
I have already uploaded ..
  • proteus + code.zip
Thanks but what was the problem sir ?:sad:
The problem was you cannot connect LED to P1 and also ADC0804 o/p because ADC o/p pins will be o/p but P1 pins will be inputs.
I want to change that ADC value to volt how to rewrite program ?
