Problem installing IC_5.0.32 on suse32_10.1
josefico
Newbie level 1
I'm geting this error when I run softload:
"symbol errno, version GLIBC_2.0 not defined in file libc.so.6"
Then I try:
"export LD_ASSUME_KERNEL=2.4.1"
before I run again softload
and then I get the next error:
"error while loading shared libraries: libdl.so.2: cannot open shared object file: No such file or directory"
What should I do?
Thanks
Jose
Then I try:
What should I do?
Thanks
Jose
It seems that you didn't install the lib "libdl.so.2" in you operation system. So install it and try again.
Gook luck!
I have the same problem in cadence installing. Anyone can help?
Whether the only method is to downgrad gcc to 2.3.2?
