problem in serial communication with hardware of ATMEGA32...
ismbn
Full Member level 3
Mumbai. india
Hi all...
I am using ATmega32. I have done this coding
int main(void)
	uart_init(103);  // set 9600 baud rate
	DDRA=0xFF;
	DDRB=0xFF;
	DDRC=0xFF;
	while(1)
		PORTA=PORTB=PORTC=0xFF;
		_delay_ms(100);
		PORTA=PORTB=PORTC=0x00;
		_delay_ms(100);
		print('A');  // send 'A' via usart
and burned (using USBasp for burning)it with Fuse setting for external ceramic resonator...
LOW Fuse = 0xCE;
HIGH Fuse = 0xC9;
But i am getting the correct communication on 600 Baud rate not on 9600 Baud rate...
I not understanding where i am wrong... please help me...
I have checked the same hardware before 3-4 week, It was working fine....
Please Help Its Urgent
Ismail
I am using serial Port communication via RS232..
On TXDpin i am getting 6.40V
And on RXD pin I am getting 7.79V
is there any problem with this
Ismail
What is the ceramic resonator frequency?
Did you previously use the same hardware with the same resonator?
I hope you have connected a MAX232 between the PC and AVR
thank you
i have connected 16MHz crystal with 22pF cap...
yes i have used it... this that kit only for which we have communicated in
https://www.edaboard.com/threads/265009/
yes i have connected that MAX232... why Sir?
Ismail
You said that you measure 7v in the rx/tx pins and this is wrong , you mean the AVR pins right?
yes i have measured it.. but don't know that is it right or no?
yah this is the avr pin only
will you believe me if i will tell you i am getting 8.09 V form USBasp.. which i am using to burn the Hex
ismail
check whether MAX232 is working properly or not..........
or change MAX232 ic and see.........
Hi jjeevan007..
Thanks for the reply...
But as i told i am getting 8V from the USB... and more i am getting the correct output at 600 baud rate, if i am setting it to 9600...
after this is there is need to change the MAX... what do you think... :roll:
Ismail
i think the multimeter which you are using is not working properly, because u cant get USB voltage more than 5v,
so change the battery of multimeter and try to measure the voltage.........
jeevan
yes i think you are right.... i doing that only
ismail
Post your schematic, Most probably the problem is with hardware.
The fuse setting for oscillator may be problem.
Yes i also think the problem is with hardware only... because in simulation its working gr8.
this is a ready made kit... i have just this that i am attaching...
and the fuse bits are
Lower fuse = 0xCE;
Higher fuse =0xC9;
CKSEL0=1
CKSEL1=1
CKSEL2=1
CKSEL3=1
SUT0 = 1
SUT1 = 0
CKOPT =0
this setting is for
using external ceramic resonator.
frq. range is 1MHz and above full R/R swing in clk option
startup time = 0 ms additional delay after reset
Oscillator option= full R/R Swing
ismail
try this.........
uart_init(47);
i made
uart_init(47);
still its giving the output on 600 bps only....
but how it is possible....
ismail
  • K245.pdf
Hay I have done it....it is working fine.... I am not sure but.. there is some problem in AVR studio 6 I think. I will put some screen shots tomorrow
please see the images which cause the problem
Ismail
