Problem in output: Inverter
chetan477
Newbie level 6
surat
hello friends...
There is no error in inverter, but output is not inverted, it is same as input.......
what can be possible solution?
Regards
chetan477
Newbie level 6
surat
I am doing on Backend, ICstudio, Mentor.
There is no error till pex, and when I running on eldo,ezwave output=input
Regards
dick_freebird
Advanced Member level 5
USA
If they are -exactly- the same, you have to suspect a
short. Are the net labels in the plot showing different
netnames? Push into the cellview that is being used by
the netlister (view switching ought to have options and
defaults, schematic vs behavioral vs ...). Maybe the
schematic says one thing and the subcircuit or the
behavioral view, another.
