problem-code generating unwanted latches
indomitable12345
Member level 1
please see the attatched verilog source.when i try to synthesize this module with quartus,unwanted latches are being generated for all the output nets..it is sayin that the nets add1_temp,add2_temp,go_temp etc. are retaining their previous value through one or more paths in the always construct...can anyone help me in solving this problem??
Here I am posting the code. Please post ur codes like this. instead of creating
word doc and then uploading. The code should be indented porperly. I did it this time.
Here in ur code in the case statement you are mixing both seqential as well as
combinatorial assignments. This is a very good example of very bad verilog coding
for synthesis. I am sorry to say that. First you think about the logic you want
and then use HDL(verilog) to just discribe it.
`timescale 1 ns/1 ps
module control_unit_statemac( add1_temp,
                              add2_temp,
                              op_code_temp,
                              sel_temp,
                              d_bus,
                              push_temp,
                              pop_temp,
                              go_temp,
                              clkin_temp,
                              pclk,rs,
                              clk,
                              rst,
                              int0,
                              int1,
                              ir,
                              dz,
                              z,
                              cy);
   output [13:0] add1_temp, add2_temp;
   output [2:0] op_code_temp;
   output [3:0] sel_temp;
   inout [15:0] d_bus;
   output      pclk, go_temp, push_temp, pop_temp, clkin_temp, rs;
   input       clk, rst, int0, int1, dz, z, cy;
   input [21:0] ir;
   reg [13:0]  add1_temp, add2_temp;
   reg [2:0]   op_code_temp;
   reg [3:0]   sel_temp;
   reg [15:0]  d_out, d_bus_temp;
   reg         pclk, push_temp, pop_temp, go_temp, clkin_temp, rs;
   parameter   reset=18'd0,
               a=18'd1,
               b=18'd2,
               c=18'd4,
               d=18'd8,
               e=18'd16,
               f=18'd32,
               g=18'd64,
               h=18'd128,
               i=18'd256,
               j=18'd512,
               k=18'd1024,
               l=18'd2048,
               m=18'd4096,
               n=18'd8192,
               o=16384,
               p=18'd32768,
               q=18'd65536,
               r=18'd131072;
   parameter   a_add     = 7'b0110010,
               b_add     = 7'b0110011,
               c_add     = 7'b0110100,
               pc_add    = 7'b0010000,
               stack_add = 7'b0101111;
   reg [17:0]  p_state, n_state;
   always @(posedge clk) begin
      if (rst)
        p_state <= reset;
      else
        p_state <= n_state;
   end
   always @* begin //(p_state)
      case(p_state)
        reset : begin
           n_state <= a;
           op_code_temp <= 3'bzzz;
           add1_temp[13:0] <= 14'hzzzz;
           add2_temp[13:0] <= 14'hzzzz;
           go_temp <= 1'b0;
           pclk <= 1'b0;
           push_temp <= 1'b0;
           pop_temp <= 1'b0;
           clkin_temp <= 1'b0;
           rs <= 1'b1;
          end
        a : begin
           casex(ir)
             22'b000001xxxxxxxxxxxxxxxx : begin
                n_state <= l;
                   add1_temp[6:0] <= ir[14:8];
                   add1_temp[13:7] <= stack_add;
                   sel_temp[3:0] <= 4'b0011;
                   push_temp <= 1'b1;
                   //add2_temp[13:0] <= 14'bzzzzzzzzzzzzzz;
                   //d_out[15:0] <= 16'hzzzz;
                   //op_code_temp[2:0] <= 3'bzzz;
                   /*pop_temp <= 1'b0;
                    go_temp <= 1'b0;
                    clkin_temp <= 1'b0;*/end
                pclk <= 1'b0;
                rs <= 1'b0;
             end
             22'b000010xxxxxxxxxxxxxxxx : begin
                n_state <= m;
                   add1_temp[6:0] <= stack_add;
                   add1_temp[13:7] <= ir[14:8];
                   pop_temp <= 1'b1;
                   /*add2_temp[13:0] <= 14'bzzzzzzzzzzzzzz;
                    push_temp <= 1'b0;
                    go_temp <= 1'b0;
                    clkin_temp <= 1'b0; */
                end
                pclk <= 1'b0;
                rs <= 1'b0;
             end
             22'b001xxxxxxxxxxxxxxxxxxx : begin
                n_state <= b;
                   add1_temp[13:7] <= a_add;
                   add1_temp[6:0] <= ir[6:0];
                   add2_temp[13:7] <= b_add;
                   add2_temp[6:0] <= ir[14:8];
                   sel_temp[3:0] <= 4'b1111;
                   /*d_out[15:0] <= 16'hzzzz;
                    go_temp <= 1'b0;
                    push_temp <= 1'b0;
                    pop_temp <= 1'b0;
                end
                pclk <= 1'b0;
                rs <= 1'b0;
             end
             22'b010xxxxxxxxxxxxxxxxxxx : begin
                n_state <= d;
                   d_out[7:0] <= ir[7:0];
                   //add1_temp[6:0] <= 7'bzzzzzzz;
                   sel_temp[3:0] <= 4'b1110;
                   /*d_out[15:8] <= 8'hzz;
                    go_temp <= 1'b0;
                    push_temp <= 1'b0;
                    pop_temp <= 1'b0;
                end
                pclk <= 1'b0;
                rs <= 1'b0;
             end
             22'b011xxxxxxxxxxxxxxxxxxx : begin
                n_state <= e;
                    go_temp <= 1'b0;
                    pclk <= 1'b0;
                    push_temp <= 1'b0;
                    pop_temp <= 1'b0;
                end
                pclk <= 1'b0;
                rs <= 1'b0;
             end
             22'b100xxxxxxxxxxxxxxxxxxx : begin
                n_state <= g;
                   sel_temp[3:0] <= 4'b0010;
                   /*add1_temp[6:0] <= 7'bzzzzzzz;
                    go_temp <= 1'b0;
                    push_temp <= 1'b0;
                    pop_temp <= 1'b0;
                    clkin_temp <= 1'b0;*/ end
                pclk <= 1'b0;
                rs <= 1'b0;
             end
             22'b101001xxxxxxxxxxxxxxxx : begin
                n_state <= h;
                   add1_temp[6:0] <= pc_add;
                    go_temp <= 1'b0;
                    push_temp <= 1'b0;
                    pop_temp <= 1'b0;
                pclk <= 1'b0;
                rs <= 1'b0;
             end
             22'b101010xxxxxxxxxxxxxxxx : begin
                n_state <= j;
                   add1_temp[13:7] <= pc_add;
                   pop_temp <= 1'b1;
                    go_temp <= 1'b0;
                    push_temp <= 1'b0;
                    clkin_temp <= 1'b0; */ end
                pclk <= 1'b0;
                rs <= 1'b0;
             end
             22'b110xxxxxxxxxxxxxxxxxxx : begin
                  n_state <= n;
                     d_out[7:0] <= ir[15:8];
                      go_temp <= 1'b0;
                      push_temp <= 1'b0;
                      pop_temp <= 1'b0;
                  end
                pclk <= 1'b0;
                rs <= 1'b0;
             end
             22'b111001xxxxxxxxxxxxxxxx : begin
                pclk <= 1'b0;
                rs <= 1'b0;
                if(dz==0) begin
                   n_state <= o;clkin_temp <= 1'b1;
                end
                else
                  n_state <= q;
             end
             22'b111010xxxxxxxxxxxxxxxx : begin
                pclk <= 1'b0;
                rs <= 1'b0;
                if(z!=0)
                  n_state <= o;
                else
                  n_state <= q;
             end
             22'b111011xxxxxxxxxxxxxxxx : begin
                if(z==0) n_state <= o;
                else n_state <= q;
                pclk <= 1'b0;
                rs <= 1'b0;
             end
             22'b111100xxxxxxxxxxxxxxxx : begin
                pclk <= 1'b0;
                rs <= 1'b0;
                if(cy==0)
                  n_state <= o;
                else
                  n_state <= q;
             end
             22'b111101xxxxxxxxxxxxxxxx : begin
                pclk <= 1'b0;
                rs <= 1'b0;
                if(cy!=0)
                  n_state <= o;
                else
                  n_state <= q;
             end
             default : n_state <= reset;
           endcase
        end
        b : begin
           n_state <= c;
              //add1_temp[13:0] <= 14'bzzzzzzzzzzzzzz;
              sel_temp[3:0] <= 4'b0000;
              op_code_temp <= ir[18:16];
              go_temp <= 1'b1;
           end
        end
        c : begin
           n_state <= a;
              add1_temp[6:0] <= c_add;
              go_temp <= 1'b0;
           end
           pclk <= 1'b1;
        end
        d : begin
           n_state <= c;
              //add1_temp[13:7] <= 7'bzzzzzzz;
              go_temp <= 1'b1;
           end
        end
        e : begin
           n_state <= f;
           @(posedge clk)
        end
        f : begin
           n_state <= a;
           pclk <= 1'b1;
        end
        g : begin
           n_state <= f;
              d_out[7:0] <= 8'hzz;
           end
        end
        h : begin
           n_state <= i;
           @(posedge clk)
             push_temp <= 1'b1;
        end
        i : begin
           n_state <= a;
           end
        end
        j : begin
           n_state <= k;
           @(posedge clk)begin
              pop_temp <= 1'b0;
           end
        end
        k : begin
           n_state <= a;
        end
        l : begin
           n_state <= f;
              push_temp <= 1'b0;
           end
        end
        m : begin
           n_state <= f;
              pop_temp <= 1'b0;
           end
        end
        n : begin
           n_state <= k;
           end
        end
        o : begin
           n_state <= p;
           end
        end
        p : begin
           n_state <= a;
           end
        end
        q : begin
           n_state  <=  r;
           /*@(posedge clk) begin
            d_out[15:0] <= 16'hzz;
            push_temp <= 1'b0;
            pop_temp <= 1'b0;
            go_temp <= 1'b0;
            clkin_temp <= 1'b0;
            op_code_temp[2:0] <= 3'bzzz; end	*/
        end
        r : begin
           n_state <= a;
            push_temp <= 1'b0;
            pop_temp <= 1'b0;
            go_temp <= 1'b0;
            clkin_temp <= 1'b0;
           pclk <= 1'b1;
        end
      endcase
      /*@(posedge clk)
	   begin
	   add1[13:0] <= add1_temp[13:0];
	   add2[13:0] <= add2_temp[13:0];
	   //data[15:0] <= d_bus_temp[15:0];
	   op_code[2:0] <= op_code_temp[2:0];
	   push <= push_temp;
	   pop <= pop_temp;
	   clkin <= clkin_temp;
	   go <= go_temp;
	   d_bus_temp <= d_out[15:0];
		end
   end // always @ *
	 d_bus_temp[15:0] <= d_out[15:0];
   assign d_bus[15:0] = d_bus_temp[15:0];
endmodule
