er2212
Newbie level 6
- Joined
- Apr 18, 2010
- Messages
- 13
- Helped
- 5
- Reputation
- 10
- Reaction score
- 4
- Trophy points
- 1,283
- Location
- Northridge
- Activity points
- 1,394
I setup .synopsys_pt.setup and i am trying to use it fifo i synthesis my fifo using 90nm library i am using same library for prime time it link the library but give me following information
Information: 204 (91.07%) library cells are unused in library saed90nm_max.....
Information: 224 (100.00%) library cells are unused in library saed90nm_min.....
Information: 224 (100.00%) library cells are unused in library saed90nm_typ.....
Information: 43 (100.00%) library cells are unused in library saed90nm_io_max.....
Information: 43 (100.00%) library cells are unused in library saed90nm_io_min.....
Information: 43 (100.00%) library cells are unused in library saed90nm_io_typ.....
Information: 12 (100.00%) library cells are unused in library saed90nm_min_cg.....
Information: 12 (100.00%) library cells are unused in library saed90nm_max_cg.....
Information: 12 (100.00%) library cells are unused in library saed90nm_typ_cg.....
can anyone explain me because after that it cannot perform check_timing
