Powerpcb Excellon files ?
Mart
Junior Member level 1
Netherlands
Is it possible to make Excellon files with powerpads for cnc milling, with powerpads :?:
Or is there a other way to translate gerber files to excellon files :?:
please help :roll:
binu G
Advanced Member level 2
Bangalore
y can create a file with excellon format by selecting the device setup in the nc drill an select the fromat excellon from it
binu
Mart
Netherlands
thanks for your feedback
With selecting nc drill, y can make only a drill file in format excellon. That is not the problem. I want to make format excellon file for cnc isolation milling.
:? I can buy second-hand milling machine, which only works with excellon (hpgl) files.
gometric
Member level 1
Member level 1
look at this file, it might help doing that I don't know.
Just delete the .zip at the end and read it with your text editor.
Mart
Netherlands
powerpads can only make excellon files for drilling, but i have found a program which can convert gerberfiles for isolation milling on a cnc machine. Works wel KCam www.kellyware.com.
But it only export dxf files, which i can not use. Other option is to use KCam direct to control your cnc machine for isolation milling.
Greetings,
Mart
