Power Supply 19v 6.32a 120w HELP!
gulias
Newbie level 3
Newbie level 3
Hi i´m from Brazil and i need to make a power supply "battery charger" for my notebook, can any one help me? Thanks!
a link to toshiba´s power supply that i need.
Toshiba A75
[/url]www.toshibadirect.com/td/b2c/adet.to?poid=271193&seg=HHO&coid=-27401&rcid=-26364&ccid=1291043
ps. Sory about my english
If you are not very familiar with switchmode devices then you may consider building a linear power supply ..
Here are examples:
1) http://ludens.cl/Electron/Ps20/Ps20.html
(for <10A without Q5 and Q6)
2) **broken link removed**
(see: High Current Adjustable Regulator)
Regards,
IanP
Thanks Ian for the reply, but i´am too newbie to understant the tecnical link that you send me, but in the other link taht you send me https://ludens.cl/Electron/Ps20/ps20.gif
this is the circuit that i need? i have only to change the T1 to 24 volts? is that or i have to change some thing more?
Thanks Ian sorry for so many questions.
I would change the following:
T1-->20-24Vac
C1-->10,000µF/40Vdc
C2-->1000-2200µF/35Vdc
R2/R3-->may require correction for 19V output ..
And, as I suggested before, you don't need Q5-R9 and Q6-R10 ..
Regards,
IanP
Thanks Ian for the fast reply! ! ! ! ! !:D:D:D
