Power MOSFET (SPB160N04S2L-03) footprint using Altium
Hanooda
Newbie level 5
Good Afternoon , how's every body?
I want to get your feedback on my first footprint drawing using Altium Designer for Power MOSFET (Type: SPB160N04S2L-03) (Package:p- TO263 -7-3).
In the attchement you will find the altium footprint file. I used the PCB Layout Reference View which was provided in the datasheet to draw my footprint.
Could you check if my drawing have some mistake or not.
Looking Forward to hearing from you.
Hanooda
  • SPB160N04S2L-03.rar
Hanooda,
can you send in zip file, please
thanks,
keyur
Hanooda, it looks correct to me, as you have got the footprint from the link below,
You have also done correct by removing the middle pin,
sometimes, you could order a dummy component from the supplier, and then check against the 1:1 copy of your gerbers.
thanks,
keyur
Hanooda,
I also checked the designator of the pads, which are not correct, they have 4th pin as tab, so generally internally connected to ground ( heat desipating pad) , so try to keep that in mind, you only have configued as six pads .
thanks,
keyur
