potyo2 debugging "MCLR Vdd: Low"
krotus
potyo2
Hi, I have build potyo2 rev1 (**broken link removed**) but it doesnt work.
One problem is that selftest says "MCLR Vdd: Low", all other tests are passed. Another problem is so I have only 2.30V ISP-VDD (1.20V on 1RA1), shouldnt this be 5V when target device is selected to 16f877a? Also target device ID is not recognized (Read 0x00). What should I check first?
Thanks in advance.
krotus
potyo2
Potyo2 should be ICD2 compatible, so I want to ask if there is any program for ICD2 to statically set outputs to given levels to allow me to check them with multimeter? Thx.
wp100
Advanced Member level 5
Prime Meridian
potyo2-rev1.zip
Most icd2 clones are much simpler than the design you have built - have a look at the circuit / assembly manual from BlueRooms Inchworm design - it might help.
blueroomelectronics
Toronto, Canada
Re: potyo2 debugging
The PICkit2 has this, too bad the ICD2 doesn't.
