childs72
Member level 1
Hi guys,
I had implemented clock gating using RTL similar to below. It works well during RTL simulation. However, after synthesis, I perform simulation on post-syn netlist with sdf back-annotation. Simulation show the system does not function correctly.
Here is my hypothesis based on observaI understand that at post-synthesis stage, we have only ideal clock latency. However, due to the clock gate I inserted in RTL, I am seeing larger clock latency to registers inside "my_inst" (due to delay introduced by clock gate) compared to other non-clockgated registers outside of "my_inst"; this, in turns created hold time issue and the system is not able to function correctly.
Does my observation & hypothesis make sense? If yes, I believe I need to do something in order for the simulator (Cadence irun) to NOT annotate the delay at my clock gate cells. Can anyone suggest me how to do this?
Thanks!
Also, when I tried to report_clock_gating -gated in DC, nothing related to above RTL is reported. Does DC not recognize the code as clock gating? What should I do?
Thanks.
assign cg__clk = clk || !clk_gate_en;
my_module my_inst ( .clk_in(cg__clk),
Thanks!
Thanks.
