posedge and negedge in verilog always block
sunidrak
Full Member level 1
Full Member level 1
Bengaluru, India
hi
can anybody explain
always @(posedge clk or negedge rst)
if(rst)
q<=0;
else
q<=d;
if reset is active high and and i want apply it as posedge . . is it possible to do
regards
Sunil
The correct syntax is
always @(posedge clk or posedge rst)
if(rst)
q<=0;
else
q<=d
for active low reset
if(!rst)
q<=0;
else
q<=d;
Please consider that the required Verilog syntax for asynchronous register control hasn't to do with edges, it's actually describing level triggering.
Reactions: tpetar
    tpetar
