triquent
Full Member level 3
I tried to import the nondefault rule LEF file, but I couldn't import it. I got following error information. what is the problem? What is the exact step to use the nondefault rule to chang the clock wire width after routing?
** EXCHANGEFORMATS-USER-113 ERROR **
Cannot create database because:
db lock create failed, conflicting lock file is : LBRARY.dtp ONE WRITE ACCESS allowed:.
** CADENCE-USER-53 WARNING **
Input source will abort at next read due to limit of 1 PROBLEMs.
Added after 1 hours 2 minutes:
when I edit the nondefault rule file, should I use the same layer name as the original LEF file? ex metal or via names
