plot small signal output resistance with hspice
guoqing
Newbie level 2
Newbie level 2
I designed a voltage amp which will work under a large temperature range. Can any one tell me how to plot the output resistance vs. temperature with hspice. Using .tf I can only get one Ro value at one simulation.
Thanks!
flushrat
Full Member level 3
Full Member level 3
you can sweep temperature.
In awaves, change x-axis to temperature, and plot ro
guoqing
Newbie level 2
Newbie level 2
Can you post specific command? Thanks!
yankuangtu
Member level 3
Member level 3
can awaves plot ro?I don't know
vbhupendra
Full Member level 4
Full Member level 4
GOA, INDIA
same question : CAN awaves plot "ro" if yes wat is the options in hspice netlist for post processing.
flamingo
Member level 4
Member level 4
Use .ac analysis and plus .net command. probe zout, that is what U want. good luck.
