u931803
Newbie level 3
Hello guys,
I have nearly no knowledge in the design of PLL, so the following question came across when I tried to decide how to design the clock of my project
Suppose two clocks are mandatory: clk and clk_2x where the frequency of clk_2x is two times that of clk
Now for some reason I need either (1) a single clock clk_4x or (2) three clocks clk_p45, clk_p90 and clk_p135, in which pXX means phase shift
Considering the difficulty to design such PLL, the power consumption, and the potential routing problem, can anyone tell me if which option is better?
If clk_4x can be as high as 1.6GHz, will the answer be the same?
Thanks a lot
Thanks a lot
