fooofaaa
Junior Member level 1
I'm currently using labview to receive data sent from the microcontroller PIC18f452. I'm using visa to receive data from the pic. But the problem is the read result always zero!! I'm use a virtual serial port to interface Proteus with labview.. Also i connect the RS-232 in Proteus to a virtual terminal to enable me to see what is sent.. Although there is an output in this virtual terminal and i see that data is sent (but not alwayes!! som times it dosn't appear any thing); i cant see that this data is sent to labview.. also the baud-rate of sent and received bytes in Virtual serial port is zero>> this picture show the problem
please >> i need your help>> and i need someone to advice what to do or what i need to solve the problem ..
Regards.
Regards.
