please translate this into Hitech C
mana111
Member level 1
please i have this code written in proton picbasic and i want to write it in hitech c
can any body help pleaseeeeeeee
' Create some variables for use with LN and LOG
		Dim LOG_VALUE as Float
		Dim LOG_POWER as Float
		Dim LOG_TEMP as Float
		Dim LOG_X as Float
		Dim LOG_FACTOR as Float
		Dim LOG_XSQR as Float
		Dim LOG_N as Byte
		Dim LOG_TEMP2 as Byte
' We can't have ln(1) so we must return a zero if it is
		If LOG_VALUE.Byte0 = 0 Then LOG_VALUE = 0: Return
' The difference between LOG_N.BYTE0 and $7E will be the
' amount of 2^LOG_N's that we want to multiply times ln(2)
		If LOG_VALUE.Byte0 <= $7E Then
			LOG_N = $7E - LOG_VALUE.Byte0
			LOG_FACTOR = -0.69314718 * LOG_N
		Else
			LOG_N = LOG_VALUE.Byte0 - $7E
			LOG_FACTOR = 0.69314718 * LOG_N
		Endif
		LOG_VALUE.Byte0 = $7E
' Begin the taylor series expansion
' ln(1+LOG_X) = LOG_X - (LOG_X^2/2) + (LOG_X^3/3) -+...
		LOG_VALUE = LOG_VALUE - 1
		LOG_X = LOG_VALUE
		LOG_XSQR = LOG_VALUE
		LOG_N = 2
		Repeat
			LOG_XSQR = LOG_XSQR * LOG_X
			LOG_VALUE = LOG_VALUE - (LOG_XSQR / LOG_N)
			LOG_TEMP2 = (LOG_N + 1)
			LOG_VALUE = LOG_VALUE + (LOG_XSQR / LOG_TEMP2)
			LOG_N = LOG_N + 2
		Until LOG_N > 12
		LOG_VALUE = LOG_VALUE + LOG_FACTOR
		Return
Hi, you should precise what is the purpose of your program.
Have you already thought about it ?
this is a log routine
i know that there is a log function in hitech picc but i want it this way because it's in detail
my biggest problem is how to write this line in c
LOG_VALUE.Byte0 = 0
thanx alot
Your C form of your PIC Basic code should like this:
float log_value(float LOG_VALUE){
float LOG_POWER;
float LOG_TEMP;
float LOG_X;
float LOG_FACTOR;
float LOG_XSQR;
char  LOG_N;
      LOG_VALUE--;
      LOG_X = LOG_VALUE;
      LOG_XSQR = LOG_VALUE;
      for (LOG_N = 2; LOG_N <= 12; LOG_N = LOG_N + 2){
         LOG_XSQR  *= LOG_X;
         LOG_VALUE -= LOG_XSQR / LOG_N;
         LOG_XSQR  *= LOG_X;
         LOG_VALUE += LOG_XSQR / (LOG_N + 1);
      return LOG_VALUE + LOG_FACTOR;
thanx alot but what about these lines
these are the most important for me
Else
Endif
