[PIC] please help I need a PIC16f877A project code
Chiunit2
Newbie level 5
Please help me I need a PIC16F877A project code. I need the pic to switch 4diffrent relay from 4diffrent input and it should display the relay that's on on LCD. Please it is urgen for my school project
Show us your code and schematic so far.
If you have 4 inputs and 4 relays, why do you need the PIC? Is it just to monitor the state of the inputs?
Brian.
Reactions: RETGT
    RETGT
Please I don't have anything done yet. But the project is based on PIC16F877A please it's very urgent
Maybe you should have started working on this sooner. Edaboard isn't a free consulting service or homework/project cheating service.
We can't give you any help at all unless we know a few things:
- what compiler, IDE and programmer are you using
- what is the schematic for the hardware - we heed to know the ports the switches and relay drivers are connected to
- have you ever written code for a microcontroller before
- have you looked for any tutorials on the Internet for the environment you have (e.g. how to flash a LED, run any code in the device at all)
Susan
I don't know which Compiler you are using but I have written code using mikroC PRO PIC Compiler. Project attached. Proteus file and Schematic in PDF format is also attached.
4 MHz Crystal is used.
  • Driving Relays.rar
God bless you Okada, will check it out
