Please confirm IGBT only conducts in one direction
Normally the IGBT has an added diode chip in its package for use in situations where it is needed, a standard IGBT gives you the freedon to add your own choise of reverse diode, but there are now IGBTs with intrinsic body diodes being made
somewhat similar to the common mosfet - which does always have an intrinsic body diode ( and parastic BJT causing latchup some times )
--- Updated ---
A picture of the internals ...
--- Updated ---
and:
Thanks,
We have a reverse recovery problem in our igbt's on-body diode, so an igbt with no diode woudl be great for us.
There seems no way in digikey to sort the ones with diode, from the ones without diode.
We need to use one without diode, but with two paralleled sic diodes added by us. (sic for no rev rec)
We are currently using the IKW30N65, but it has the nuisance added diode.
How do you know that there is a "reverse recovery" problem?
And in what magnitude?
What I did:
* internet search "IKW30N65"
* found some distributors
* selected "Digi-key" (the first one, randomly)
* they show a table with 5 different "IKW30N65".
* and in the table there is a column with "reverse recovery time". That´s what you are looking for.
* all 5 types with different trr values. So your part number is not complete. It misses the exacle the information what you are looking for.
So we don´t have the information about your trr. We can not recommend faster ones.
What I did next:
* Digi-key search for "single IGBT"
* select for: >650V, >30A, TO220, Infineon
* sorted for increasing trr
* The fastest ones show "25ns", pretty fast I think.
* But there are many that show "-" in the trr column.
* I had an idea "why".:unsure:
* so I clicked on the "datasheet" button of one with similar name as yours: "IGP30N65F5XKSA1-ND"
* datasheet first page symbol shows no diode
* datasheet first page text says: "•Ideal fit with SIC Schottky Diode in boost converters"
All in all it took about 2 min of using the internet.
Writing this post took much longer.
Not done, but also possible solutions:
* go to other distributors and do search
Done:
* Infineon product search:
--> Press the link "without antiparallel diode" --> https://www.infineon.com/cms/en/pro...es/discrete-igbt-without-anti-parallel-diode/
* internet search "igbt SiC diode 650V"
--> found an article where INFINEON builds IGBT with internal fast SiC diode.
I did not spent more time to find out partnames.
IGBTs' can turn on very fast, < 15nS, if you slow the gate drive on your existing system your issues with possible Trr & Irr may go away ....
--- Updated ---
--- Updated ---
One without diode:
Thanks,
Just keep in mind that if you're truly seeing reverse recovery behavior, then even if you do use an IGBT without an integrated diode, you will very likely need to add your own external diode. But you can choose the best one for your needs.
Indeed, that is annoying.
Maybe you could just use a SiC MOSFET instead of the IGBT?
Thanks, yes, i am able to find igbts with and without diode, but the key point appears to be that igbts without diode are rather rarer and possibly not a good idea to put in the BOM, as there may well be supply issues?
Its difficult to assess how rare the "no diode" ones are.
Isn't it strange that for say 20kHz converters, we dont see 1200v igbt's in parallel, instead of single 650V devices which may not have the surge voltage rating.
So, Why dont we see, say two IGBTs in parallel, being driven by the same gate driver, in 2kW switch mode converters at 20khz fsw?
Surely there's no reason that they can't be paralleled, as long as enough damping is put on the gates?
Although many have a negative temp co and so paralleling would be bad for those ones.
IGBT's since they have BJT outputs are NTC in linear region yet slightly PTC when saturated and approx NPO at 10% rated current. They are lower capacitance out yet FET's have lower RdsON than BJT's Rce for same size chip.
losses are sum of static and dynamic from charging slew rates
Imagine Rce tempco as the difference between PN junctions for CB vs BE as both are saturated with declining hFE current ratios for increasing saturation.
GaN FETs promise to be 30x faster at HV when processes improve.
Si is already very mature with over 7 generations of design at Mitsubishi.
