place_opt command - IC compiler (synopsys)
ee1
Full Member level 2
Hi all,
i have a question regarding "place_opt" command:
can the tool decide adding cells (buffers for example) in order to optimize the design? or it place only the cells that exists in the netlist ?
thanks!
shelby
Full Member level 2
place_opt does placement + optimization, so yes, it will add buffers in the design to fix design rule violations (max_cap, max_trans), add in buffertrees for high fanout nets, and to help fix timing violations
rca
Advanced Member level 5
Marin
just to complete the shelby's answer, it could add or removed buffer/inverter is needed.
Reactions: ee1
    ee1
vidyacharan
Junior Member level 1
"place_opt" command places the stdcells present in the netlist and adds extra buffers, inverters for the optimization.
it even performs high fan out synthesis for all high fan out nets, excluding clock nets.
Clock nets are treated as ideal nets.
Reactions: ee1
    ee1
