pin's name is not visible in cadence layout XL
mohamis288
Full Member level 3
Hello,
in cadence virtuoso, I can place pin as you can see in the navigator panel in the following image. but its name is invisible. what can I do to solve this problem?
Then try to create the pin again. On "Update Components and Nets" go to "I/O Pins" and on "Pin Labels" mark "Create Labels As-> Text Display". Click on Options and mark Layer Name and Layer purpose "same as pin".
Hope it works.
Sorry I do not know where it is. Can you please address clearly. I have checked pin property and option->display... But I do not find such things there
Hope it works.
On Layout XL/GXL you have the "Update Components and Nets".
