Hello,
I have a question towards the pin definition on a poly net. As a simple example when I have a layout of the inverter and define a pin for its gate which has been connected by poly, it will not recognize by the LVS check as the port. However, it is obvious as the pin in the Navigator Windows of the layout editor. Just I should create an M1-Poly Via and after that define a pin by M1. I had not any problem with our past PDK like Xfab and AMS.
I would be appreciated to tell me what should I do for that? What's your suggestion?
Best,
