PicKit3 and dspic30f4011 with MPLAB
slink3r
Newbie level 5
Palmdale
I have a pickit3, and I've been programming a dspic30f4011.
I used the sample code from the back of the programming guide.(I'm using the C30 library)
I have a 10k resistor from Vdd to MCLR, a 10ohm from Vdd to Avv, a 1uF cap across the primary vdd/vss line, and I have the cables all hooked up correctly.
I write the code, it verifies, I read the code, I export the hex, then close MPLAB.
When I re-open MPLAB and read the PIC again, the dissassembly listing has nothing, and program memory is NOPing at me.
Any ideas?
